1987 Saab 900 Turbo - Born From Jets
Strani i domaci projekti koji su interesantni,rest-mod projekti,itd.....
Postod Carlsson » 31 Dec 2011, 19:35
evo jedan zanimljiv projekat Slika
preljepa 900-ka kabrio sa "malim" tuningom...a krajnji rezultat je ovakav: 335 konja na tockovima i obrtni moment od 450 Nm Slika
ovo je njegov prvi automobil koji je kupio sa 17 godina u ne bas tako sjajnom stanju, ali godinama ga je sredjivao i ovo je krajnji rezultat, po meni impresivno Slika
Engine: 2.0-liter 16v four-cylinder B202 bored 0.040 over with Mahle forged pistons, Total Seal rings, balanced, blueprinted, Megasquirt v2.2 standalone engine management, KnocksenseMS knock detection system, Ford EDIS distributor-less ignition system with crank-triggered wasted-spark, Garrett T3/T4 hybrid .60/.63 turbo with stage 3 exhaust wheel, ceramic-coated TA-31 hi-flow turbo exhaust housing, Siemens 60 lb/hr fuel injectors, stainless mandrel-bent equal-length header, 3" downpipe, 1.5" external wastegate atmospheric dump pipe, TiAL 38mm wastegate, Innovate wideband o2 sensor, Precision front-mount intercooler with 2.5" aluminum piping, 2.3-liter head and 2.1-liter intake manifold, 8.75:1 compression, 900S intake cam, '85 900T exhaust cam, Magnaflow 3" cat-back exhaust with Viggen tip, solid motor mounts, uprated 3-bar fuel pressure regulator, 3" cold-air intake, oil catch can
Drivetrain: five-speed manual with Swedish Dynamics kevlar/sintered iron clutch, Sachs pressure plate, larger pinion bearing, stronger shift forks, strongest five-speed case, SaabSavior short shifter, Quaife LSD, Saab Rally steel differential cover, autobahn gear set
Brakes: slotted and drilled rotors with ceramic pads, black painted calipers
Suspension: Koni adjustable shocks, Intrax springs, SaabSavior aluminum rally skidplate
Wheels & Tires: 18x7.5" Sportmax 962 wheels with 225/35 R18 Yokohama Parada Spec-II tires
Exterior: OE European Airflow kit with fluted wheel arches, late-900 Convertible rear spoiler, OE Saab Convertible rear decor panel, smoked E-code headlights with 8000K HID bulbs, OE Airflow foglights, Edwardian grey paint, new convertible top, color-matched grille, smoked corners and side indicators
Interior: Corbeau GTS-II black/grey microsuede sport seats on custom rails, black microsuede interior panels, dyed black door panels, carpet and trunk, ProSport digital wideband air fuel ratio, oil pressure, oil temp and boost gauges, OE Saab/Fittipaldi Rally steering wheel, custom gauge cluster
Audio/Visual: Sony Xplod head unit, components and amp
i koga zanima, evo i link za cjelu pricu sa svim izmjenama Slika
Re: 1987 Saab 900 Turbo - Born From Jets
Postod nik 900t » 01 Jan 2012, 17:46
strasan je u svakom pogledu mogu misliti kako ide sa tom snagom jos kabrio.koliko li ga je kostalo sredjivanje ....
Postod AERO » 26 Jan 2012, 02:14
....i u novinama je bio Slika
Postod AERO » 19 Apr 2012, 05:12
Postod troll 9-5 » 19 Apr 2012, 15:02
He he pa ovo nema ni u dinastiji Slika
Postod AERO » 28 Maj 2012, 03:06
Postod AERO » 15 Sep 2012, 00:16
HIRSCH
Postovi: 579
Pridružio se: 14 Jan 2012, 00:00
Postod HIRSCH » 15 Sep 2012, 12:09
....bolje su mu one prve felne...nebi ja tu nista menjao.. Slika
Postod AERO » 26 Nov 2012, 00:20
Postod Gost » 26 Nov 2012, 01:02
Postod troll 9-5 » 26 Nov 2012, 03:03
Postovi: 329
Postod ninsaki » 01 Avg 2013, 10:57
Ajde jedno pitanje , zbog cega je ona "rozeta" bolja od standardnog izduva na 900 og?
Postod AERO » 01 Avg 2013, 13:32
Estetika i malko promena u zvuku (ako nije divca vec prava sa "komorom") :sr:
Povratak na “SAAB PROJEKTI”
