TEHNICKA DOKUMENTACIJA ZA SAAB 96
Saab 96 (1967)
Saab 96 Specifications (1967)
Saab 96 Estate (1967)
Saab 96 V4 (1971)
Re: TEHNICKA DOKUMENTACIJA ZA SAAB 96
SAAB 96 Bullnose
ZIP!SAAB 96 1960
ZIP!! Accessories Saab 96 1962
ZIP!SAAB Two stroke Parts catalog - HTML/JPEG
Competetion Turning SAAB two stroke engines article
SAAB 96 1960
SAAB 96 1964
Saab Factory Service manual 1964
Accessories Saab 96 1964
Article about the SAAB two stroke Engine - "Look Ma' - No Valves!"
ZIP!SAAB 96 1960
SAAB 96 1960
SAAB 96 1964
[link_open=https://onedrive.live.com/view.aspx?res ... pp=WordPdf]Saab 96 1964 Service Manual[/link_open]
Moze da se skine u PDFu mnogo bolje se vidi ;) Ima oko 250 strana.
BRAKES
Description Model Manufacturer Part Number
Rear wheel cyl. V4 95, 96 and Sonett Beck Arnley 072-2223
Same V4 95, 96 and Sonett Lockheed LW11396 and AP111-90-01
Rear wheel cyl rebuild kit V4 95, 96 and Sonett Beck Arnley 071-1465
Rear Brake Hardware Kit Five bolt 95, 96 and Sonett Lockheed SSB1
Rear shoe spring V4 95, 96 and Sonett NAPA 80724
Front pad steel shim V4 95, 96 and Sonett Beck Arnley 084-2022
Brake master cyl. Rebuild kit V4 95, 96 and Sonett Beck Arnley 071-1614 and 071-1622
Same V4 95, 96 and Sonett Saab 7836430
Front brake pads V4 95, 96 and Sonett Beck Arnley 082-0464
Pad spring RH V4 95, 96 and Sonett Saab 7323918
Pad spring LH V4 95, 96 and Sonett Saab 7323900
Front brake hose V4 95, 96 and Sonett Same as rear MGB?
Front brake hose V4 95, 96 and Sonett Beck Arnley 073-0143
Caliper assembly rebuilt V4 95, 96 and Sonett Checker Auto C7650
Austin America's used the same caliper piston assembly and can be used in a vintage Saab
Caliper rebuild kit V4 95, 96 and Sonett Beck Arnley 071-1432
Caliper piston V4 95, 96 and Sonett Saab 7323793
Same V4 95, 96 and Sonett Moss Motors 181-925
Same V4 95, 96 and Sonett Lockheed 114713
Front rotor splash guard V4 95, 96 and Sonett Saab 7328040
LH caliper wheel cyl. V4 95, 96 and Sonett Saab 7328453
RH caliper wheel cyl. V4 95, 96 and Sonett Saab 7328461
LH caliper complete V4 95, 96 and Sonett Saab 7352495
RH caliper complete V4 95, 96 and Sonett Saab 7352503
Master to slave cyl. Hose V4 95, 96 and Sonett Saab 7371420
Brake light switch V4 95, 96 and Sonett Intermotor 51620 and 56480
Same V4 95, 96 and Sonett Lucas 34619
Rear wheel cyl. Rubber boot 95, 96 and Sonett Saab 7192735
Hand Brake Cable 93, 95, 96 Saab 7199227
Clutch
Slave cyl All V4 95, 96 and Sonett Saab 8809196
Slave cyl. Rebuild kit All V4 95, 96 and Sonett Beck Arnley 071-0897
Clutch throw out bearing All V4 95, 96 and Sonett Beck Arnley 062-1107
Same All V4 95, 96 and Sonett Sachs 3159 140 037
Same All V4 95, 96 and Sonett Brut Power 96041
Same All V4 95, 96 and Sonett BCA/National VW-1006-C
Same All V4 95, 96 and Sonett NAPA N1845
Clutch disc alignment tool All V4 95, 96 and Sonett Motormite 1466
Pressure plate All V4 95, 96 and Sonett Beck Arnley 064-7194
Same All V4 95, 96 and Sonett Sachs 1882 251 101
Same All V4 95, 96 and Sonett Borg Warner 98194
Same All V4 95, 96 and Sonett A/P 30-09105
Pressure plate All Two Stroke Same as Porsche 356 and 1600 ??
Pressure plate All Two Stroke Sachs 211141025D
Clutch Master Cylinder 1972 96 and ? Same as Saab 9000? 89 44 993
Clutch Master cyl rebuild kit All V4 95, 96 and Sonett Beck Arnley 071-1671
Clutch pilot bearing All V4 95, 96 and Sonett BCA/National 105
Clutch disc All V4 95, 96 and Sonett Beck Arnley 064-8194
Same All V4 95, 96 and Sonett Sachs 1861 287 134
Same All V4 95, 96 and Sonett Borg Warner 99194
Same All Two Stroke Sachs 0610501 or 1862097303
Ignition
Electronic Ignition Stroker Dist. VJ3BR4 Pertronix Kit# 1831
Electronic Ignition Stroker Dist. VJ3BR2T Pertronix Kit# 1832
Distributor cap All V4 95, 96 and Sonett Beck Arnley 174-4796
Same All V4 95, 96 and Sonett Borg Warner C546
Same All V4 95, 96 and Sonett Motorcraft DH-157
Same All V4 95, 96 and Sonett NAPA EP274
Rotor All V4 95, 96 and Sonett Beck Arnley 173-5257
Same All V4 95, 96 and Sonett Borg Warner D555
Same All V4 95, 96 and Sonett Motorcraft DR-92
Same All V4 95, 96 and Sonett NAPA EP-278
Ignition Coil All V4 95, 96 and Sonett Beck Arnley 178-8009
Same All V4 95, 96 and Sonett Borg Warner E40
Same All V4 95, 96 and Sonett Motorcraft DGC-13
Same All V4 95, 96 and Sonett NAPA IC64
Same All V4 95, 96 and Sonett Bosch "Blue" Coil ?
Points All V4 95, 96 and Sonett Beck Arnley 171-1613
Same All V4 95, 96 and Sonett Borg Warner A520
Same All V4 95, 96 and Sonett NAPA CS313
Points 1961-1964 95, 96 Bosch 1 237 013 006
Points 1965-1966 95, 96 Bosch 1 237 013 040
Condenser All V4 95, 96 and Sonett Bosch 1237330205433
Spark plug wires All V4 95, 96 and Sonett Borg Warner CH7482
Spark plugs (Platinum) All V4 95, 96 and Sonett Champion 3322
Same All V4 95, 96 and Sonett NGK 6764
Spark plugs (standard) All V4 95, 96 and Sonett Beck Arnley 1765084
Same All V4 95, 96 and Sonett Champion 302
Same All V4 95, 96 and Sonett NGK 7131
Same All V4 95, 96 and Sonett AC Delco R43XLS
Voltage Regulator All V4 95, 96 and Sonett Checker Auto 26-5005/3011
Distributor centrifugal advance All V4 95, 96 and Sonett Checker Auto 30-0982
Distributor Drive Shaft All V4 95, 96 and Sonett NAPA BK601-1444
Electronic Breaker All V4 95, 96 and Sonett Pertronix Ignitor 1847
Suspension
Shock absorbers front All V4 95, 96 and Sonett Gabriel 82607
Same All V4 95, 96 and Sonett NAPA 94005
Same All V4 95, 96 and Sonett KYB KG4524
Same 1956-73 93, 95, 96, Sonett Koni 80C-1238
Shock absorbers rear 1966-1974 Sonett Gabriel 82622
Same 1966-1974 Sonett NAPA LE10008
Same 1967 & up 95, 96 and Sonett KYB KG4540
Same 1956-60 93 KYB KG4006
Shock bushings (two piece) All V4 95, 96 and Sonett Saab 8920894
Front wheel bearing All V4 95, 96 and Sonett Saab 7079262
Outer front axle seal All V4 95, 96 and Sonett Saab 7093974
Lower control arm bushing All V4 95, 96 and Sonett Saab 7184443
Upper control arm bushing All V4 95, 96 and Sonett Saab 7163603
Rear axle bushing All V4 95, 96 and Sonett Saab 7082381
Rear axle stop straps All V4 95, 96 and Sonett Saab 7802506
Trailing arm axle bushings All V4 95, 96 and Sonett Saab 7089964
Upper control arm buffer All V4 95, 96 and Sonett Saab 7071145
Tie rod ends All V4 95, 96 and Sonett Auto Zone 011940 ES2164
Same All V4 95, 96 and Sonett Ocap 0282-400
Same All V4 95, 96 and Sonett Vera 60-02867
Same All V4 95, 96 and Sonett CEW 4955-000
Same All V4 95, 96 and Sonett Beck Arnley 101-0289
Same All V4 95, 96 and Sonett Scan-Tech 85-624
Same All V4 95, 96 and Sonett Quinton Hazel QR1422, not confirmed.
Same All V4 95, 96 and Sonett Saab 899333
Ball Joints All V4 95, 96 and Sonett Saab 7372170
Outer CV boot All 95, 96 and Sonett 1965-up Saab 7849680
Inner "T" driver axle boot for all non-rubber donut axles Saab 8910374
Body
LH door window wipe seal 93, 95, 96 Saab 7111339
RH door window wipe seal 93, 95, 96 Saab 7111347
Trunk lid seal 1960-1973 96 Saab 7166978
Seal for fresh air scoop 1960-1973 95,96 Saab 7168412
Hood seal 1965-up 95, 96 Saab 7319445
Headlight inner retaining screw 1965-up 95, 96 Saab 7867864
Front grill emblem 1969-73 95, 96 & 1969-72 99 Saab 8215865
Exhaust hanger (hour glass) 93, 95, 96, Sonett Saab 9336215
Front directional unit Sonett 1968-69 Lucas L632
Rear hatch glass lift supports Sonett III Steady Lift E072-862
Engine & Transmission
FoMoCo Carb rebuild kit V4 All NAPA 2-5520
Front motor mounts (low profile) V4 All NAPA 6021061
Fan Belt V4 All Dayco 15400
Same V4 All NAPA 09903 or 257425
Water pump V4 All SKF VKPC84400
Same V4 All Meyle 8136036363
Same V4 All Vera 5700778
Same V4 All Quinton Hazel QCP 538
Water Pump rebuild kit V4 All Ford 0405599
Water Pump Bearing V4 All Ford 0405173
Water pump backing plate V4 All Saab 8833923
Coolent temp sender V4 All NAPA TP6067
Upper radiator hose V4 All Dayco 81041
Lower radiator hose V4 All NAPA 7446
Balance shaft seal in timing gear cover V4 All BCA/National L2012
Balance shaft bearings V4 All AE AE J2002
Thermostat V4 All NAPA 137
Radiator cap with 1" long plunger Measure plunger to be sure NAPA 703-1410
Radiator cap with shorter plunger Measure plunger to be sure NAPA 703-1460
Oil Filter V4 All Fram HP1 or PH16
Oil pan drain plug V4 most but not all… NAPA 704-1036
Oil pressure switch V4 All Autozone 123901 OP23081
Same V4 All NAPA OP6615
Same V4 All Ford D4AZ-9278A
PCV Valve V4 All NAPA 209255
Fuel Filter 93, 95, 96 and Sonett NAPA 3011BP
Transmission input shaft seal V4 All Saab 719409
Transmission shift shaft boot 93, 95, 96 and Sonett Saab 8910374
Rear main transmission seal All ?? Saab 8811101
Same All ?? Ford D2RY-6701A
Output shaft seal Later drivers (non-rubber donut) Saab 7167463
Input shaft seals 93,95,96 and Sonett Saab 7194095
Air filter Sonett All V4 Saab Discontinued
Same Sonett All V4 NAPA 2369
Same Sonett All V4 Air Refiner AR112
Same Sonett All V4 Baldwin PA 1748
Same Sonett All V4 Gravely L 823DE
Same Sonett All V4 Wix 42369
Stroker Piston Rings 750cc & 850cc Cast Iron Hastings Get catalog for information
Pistons V4 All Sealed Power 397P (standard)
Rings for above V4 All Perfect Circle 51030 (standard)
Valves, valve seats, valve springs V4 All, same as 2.81 or 2.31 1970's vinatge Fords
Connecting Rod Bolts V4 Pioneer 853013 (V8 Ford 289/302 5/16)
Flywheel Bolts V4 Ford D4FZ*6379A (10mm)
Oil Pump Drive Shaft V4 Ford D2RY-6A618
Miscellaneous
Rear muffler V4 All Saab 8838005
Rack and pinion rubber boot 93, 95, 96 and Sonett Volvo! 271-545
2" dia. Black heater duct flex hose 93, 95, 96 NAPA 825-4026
[link_open=http://www.vsaab.com/PartsBin/partsource.htm#Miscellany]Alternate SAAB parts[/link_open]
Clutch
Ignition
Suspension
Body
Miscellaneous
