UOBICAJENE SKRACENICE
Brosure,prospekti,user manual-si,itd.
Postovi: 7136
Postod AERO » 26 Mar 2012, 17:38
....nadjoh kod amera,pa reko da imamo i mi.
Opste poznate skracenice s kojima se susrecemo kad se sunjamo po stranim forumima, ali vrlo cesto se zamislimo oko neke....barem ja Slika
2SN = 2-door sedan (aka 'notchback')
3 door = 2 door + hatch.
3CK = 3-door hatchback
4SN = 4-door sedan
5CK = 5-door hatchback
8V = Eight Valve
16V = Sixteen Valve
AAV = (8v) Auxilliary Air Valve
AC = Air Conditioning
ABS = Anti-Lock Brake System
AG = Autoglym ... great cleaning/polishing range for Classic 900s
AIC = Automatic Idle Control
AMM = Air Mass Meter
APC = Automatic Perfomance Control Slika KLIK
ATF = Automatic Transmission Fluid
B201 = The engine in the 99/C900 8V. "B" is for benzine i.e. petrol / gasoline. A 2 liter gas engine with 1 camshaft (came in B type & H type variants)
B202 = The engine in the C900 16V. A Gasoline ("B" for benzine / petrol) powered 2 liter engine with 2 camsafts.
B204L = A gasoline (B = Benzine i.e. petrol) 2 liter engine with 2 camshafts, 2 balance shafts (2 + 2 = 4), and a Low Pressure Turbo.
B212 = A gasoline ("B" for benzine / petrol) powered 2.1 liter engine in the C900 16V NA with 2 camshafts (only in some markets)
B234 = The 2.3 engine from the SAAB 9000. A gasoline ("B" for benzine / petrol) powered 2.3 liter engine with 2 camshafts and 2 balance shafts (2 + 2 = 4) A popular performance increasing head which can be used on the 16V block.
BOV = Blow off valve
BPV = (Turbo) By Pass Valve
CD = Corps Diplomat
CEL = Check Engine Light
CET = [by US owners] Commemorative Edition Turbo
CIS = Continuous Injection System (refering to the type of fuel injection)
CPS = Crank Position Sensor
CSI = Cold Start Injector
CTS = Coolant Temperature Sensor
CV = convertible
DIC = Direct Ignition Cassette
Dizzy = Distributor
DTC = Diagnostic Trouble Code
ECU = Electronic Control Unit
EGR = Exhaust Gas Recirculation system
ELCD = Evaporative Loss Control Device
EMS = Engine Management System
EP = EcoPower
EV1 - Experimental Vehicle 1
FMIC = Front Mount Intercooler
FPR = Fuel Pressure Regulator (See LPT)
FPT = Full Pressure Turbo
GL = Grand Luxe
GLE = Grand Luxe Elegant/Extra
GLS = Grand Luxe Super
IC = Intercooler
K-jet = Bosch's K-Jetronic CIS
LH = Bosch's LH (Luftmassenmesser Hitzdraht) (Using hotwire AMM) Injection
LPT = Low Pressure Turbo
LSD = Limited Slip Differential
Meg's = Meguiars ... another great cleaning/polishing range for Classic 900s
MY = Model year (like, MY2008 - model year 2008)
NA = Naturally Aspirated
NTC = negative temperature coefficient
OS = Oxygen Sensor
PAS = Power Assisted Steering
S = Sport as in 900S
SAAB = Svenska Aeroplan Aktiebolaget
SC = Saab Central
SE = In the U.S. and Canada not a badged designation, but understood to mean "special edition" such as the 1991 Monte Carlo, Commemorative Edition, and Spring Time In Sweden edition.
SE = In non U.S. / Canada markets, a model with the SE badge but not necessarily special.
SID = saab infotainment display
SMIC = Side Mount Intercooler
SPG = Special Perfomance Group
SRS = Supplemental Retraint System (Saab's Airbag)
T = Turbo
T5 = Trionic 5 System
T7 = Trionic 7 System
T8 = 8 Valve Turbo
T8S = T8 Special ... notice that the UK model is very different to the Swedish model, but both are referred to as the T8S
T16 = 16 Valve Turbo
TB = throttle body
TPS = Throttle Position Sensor
WUR = Warm-up Regulator
XS - Executive Special
Postovi: 7136
Re: UOBICAJENE SKRACENICE
Postod AERO » 15 Apr 2012, 06:19
TAZZ je napisao:
AERO je napisao:
TAZZ je napisao:Slobo odlican je! Samo 3" downpipe, da lakse dise... i dobijas brzi spool. Extra je lepotan!
- Sta znaci: 3" downpipe
- Sta znaci: brzi spool
Ako nije problem zbog nas koji se ne razumemo Slika
Hvala Slika
DP je izlaz iz turba, Down- Dole, Pipe-Pipica, cevulja, sulundar... kako hoces...
Downpipe, kad je veci, dozvoljava veci protok izduvnih gasova iz motora, znaci samim tim i brzi i laksi izlaz izduvniih gasova van turba... Samim tim, brzi izlaz, prelaz preko turbinskog kola, samim tim lakse dishe auto...
Sto nas dovodi do brzeg spoola, tacnije kraci vremenski period da se turbo zavrti i dodje do punog kapaciteta kompresorskog dela.
Sto ce reci uzrocno=posledicna veza... Lakse dise auto, Brze se zavrti turbo, manja temperatura na samom turbinskom kolu ... Slika
Postovi: 7136
Postod AERO » 15 Apr 2012, 06:23
TAZZ je napisao:
AERO je napisao:Zamolio bih nekog od ukucana,da nam napise:
-Zasto se kaze: Saab bez Turba je kao Milka bez cokolade,ili da je "sisavac"
HVALA Slika
Pa zato sto SISA vazduh....
Nema turba nema prisilnog ubacivanja vazduha u motor...
N-A- naturaly aspirated- prirodno sisa (onako zemunsko-beogradski)
Turbo ne daje samo snagu, daje OBRTNI MOMENT! A preticanja, medjuubrzanja na srednjim obrtajima su i jesu MOMENT. Ali kad se to uskladi sa razvojem snage, i prirastom snage u zavisnosti kakava je krivulja KS i NM, tu vidimo sta je TURBO SAAB... Slika
Postovi: 7136
Postod AERO » 15 Apr 2012, 06:25
TAZZ je napisao:CUT OFF je izraz za... CUT- Odseci... OFF- OD... Strucno, prekid dotoka goriva u motor zbog prevelikog nadpunjenja, da bi se sacuvao motor, znaci ECU dobija onfo da je preveliki pritisak u usisnoj grani, pa prekida rad pumpe nakratko, da bi spustio pritisak nadpunjenja, Nema goriva, nema sagorevanja u motoru, nema izduvnih gasova, nema turba, nema pritiska... ovo radi ECU u sekundi, a kad se desi, jooooj... mnogo neprijatno, ima se osecaj kao da je nesto puklo u motoru, pad pritiska nad punjenja, usporavanje, i kad se sve smiri, posle 2-3 sekunde, opet imamo normalan rad turba. Tako barem radi TRIONIC.
Postod TAZZ » 15 Apr 2012, 10:22
FUELCUT = CUTOFF
B204L motor nije low pressure, on je Full pressure motor sa nadpunjenjem od oko 0.8-1 Bara...
B204E i B204S su motori niskog pritiska i 0.6 Bara nadpunjenja
B204R motor koji je vozen u 9-3OG je recimo HOT ili HIGH OUTPUT TURBO.. i nadpunjenje je oko 1.1-1.15
Postovi: 7136
Postod AERO » 15 Apr 2012, 10:36
AERO je napisao: Sta znaci:bullet proof ?
Sta znaci:blowby?
Hvala Slika
TAZZ je napisao:
Bullet proof motor je sinonim za B2x4 motore, jer nemaju Blowby.
Blow BY- Javlja se kod niskofrikcionih motora(B2x5) jer su im karike 1.5-2-2.5 cinimi se, a kod 2x4 motora su 1.75-2.5-3 mere su u mm.
Kada dodje do nadpunjenja turba u motoru, prisilni vazduh, prolazi pored karika i ide direktno u karter.
Takodje i kada imamo paljenje smese, zbog brzog Flame Front-a, moze doci i dolazi do prolaska flame-a prema karteru( spremishtu ulja) a sve to pod povecanim pritiskom nadpunjenja, i onda dobijamo BLOWBY, i BRZU degradaciju ulja unutar kartera... Nema mogucnosti da ulje iz turba izlazi prema karteru, pa turbo izbacuje ulje svuda... na turbinski deo direkt u izduv, na kompresorski deo, pa sagoreva i ulje u cilindrima, dize pritisak ulja unutar glave motora- vise uljnih para... puna usisna glava ulja... itd itd itd...
Kada dodje do BlowBy, onda je samo pitanje sta ce prvo crci na motoru, turbo, cilindri, klipovi, balansne osovine... A potrosnja ulja je STRAOBALNA.
Postovi: 7136
Postod AERO » 15 Apr 2012, 11:32
Hvala Slika
Postod TAZZ » 15 Apr 2012, 12:41
Molim...
san_šabacisko
Postovi: 1435
Lokacija: Šabac
Postod san_šabacisko » 30 Mar 2015, 09:16
TAZZ je napisao:
[/quote]
jel to samo na B205?
kako sprečiti to? otvor na karteru?
i kako ustanoviti da li je ulje zbog toga izašlo svuda ili zbog nečeg drugog (na bilo kom motoru)?
:9000CC: 1987.
:NG900Cab: 2002.
:9000CC: 1988.
Povratak na “SAAB TEHNICKA DOKUMENTACIJA”
