Kako bi uz precizan upravljač na stazi auto što bolje lezao ogibljenje je totalno obnovljeno i ojačano raznim polugama za sprečavanje uvijanja.Evo ukkratko i informacije kako je to teklo.
Monster Strut Brace with Torque Limiter:
This is the new strut brace that we have developed to replace the weak stock unit. This new piece is made of aluminum and is much stiffer than the stock piece. Additionally, the design has been improved in include a brace that bridges directly across from each strut tower and ties them together. We have also incorporated a top engine mount into the brace to help stabilize the twisting forces of the engine. This unique element uses a bushing stabilizer that rises from the back of the engine to connect to the brace extension.
Subframe Brace:
Another new piece is this subframe brace. This piece is wider than some other units. In addition to have multiple attaching points to limit subframe twist, the positioning and extra width act to protect the oil pan from impact. Knowing all the cracked oil pans out there, this piece does double duty. Below are the pictures of the finished product after powder coating.
Front Suspension:
We rebuilt the front suspension using adjustable Koni sport strut inserts and H&R springs to lower the car about 30mm. Also, you can see that we replace all the stock suspension bushing with poly bushings from PowerFlex.
Rear X-Brace:
Not to leave the rear hatch area unaddressed, we developed what we call the "X-Brace" to tie the rear shock towers together and limit body flex in the hatch opening.
Rear Springs and Shocks:
The rear suspensionn was rebuilt using adjustable Koni shocks and H&R springs. Combined with the other upgrades, the suspension should handle what ever we want to throw at it.
Rear Axle Reinforced:
In order to handle the additional power and stress that we are planning to throw at this car, we throughly reworked the rear axle. To limit twisting forces, we closed the stock C-channel which you can see in the first photo. We also added the diagonal bars for further strength. Lastly, to limit any flex where the hubs attach to the axle, we added additional reinforcing plates to both sides. These can be seen in closer detail below.
Suspension Arms:
As part of the total rebuild, all parts are either being replaced or refreshed. Attached below are the suspention arms before and after the blast cabnet.
MP Performace Sway Bar:
MP Sway Bar Installed - With the installation of the performance sway bar from MP Performance, the rear axle should be sufficiently stiff.
Ogromna šipka za(Vidi gore opširnije-Monster Strut Brace with Torque Limiter) sprečavanje uvijanja, specijalno je razvijena od strane čoveka koji sprema trkačke NASCAR mašine, tako da ovo sigurno ima veliku ulogu u sportskoj voznji, šta mislite?
Šipke su postavljene(Gore-Rear X-Brace)i u osetljivom zadnjem delu automobila, tako da su sve osetljive tačke ojačane.
Ojačanja su uradjena i na ramu(Subframe Brace)kako bi sada mogao da primi duplo veće opterećenje, vrhunski uradjeno.
Zadnja osovina(Rear Axle Reinforced)je takodje dodatno ojačana kako bi se primila veća snaga i pritisak koji će biti prisutan.Dodate su i dijagonalne šipke koje za koji procenat više učvršćuje osovinu.
Kada je završen posao sa učvrćivanjem, krenulo se sa podešavanjem ogibljenja.Prednje ogibljenje( Front Suspension)je totalno sportski podešeno sa Koni štelujućim amortizerima i H-R sportskim oprugama uz koje je automobil nizi za 30mm.Takodje su na prednjoj osovini standardne kugle(čaure)zamenjene PowerFlex čaurama.
Zadnje ogibljenje(Gore-Rear Springs and Shocks)je sastavljeno isto od štelujućih Koni amortizera i H-R opruga koje utiču na to da ovaj prelepi SAAB 900 nema nikakve bojazni od brzih krivina na Nirburgringu.
Uzgred, zadnje ogibljenje je dodatno učvršćeno sa šipkom iz MP Perfomansa(MP Performace Sway Bar).Ramena su isto obnovljena i zamenjena kako bi sve bilo pod konac, sportski čvrsto i stabilno.
Zadnje ogibljenje:
Ramena:
