Poruke koje daje SID
Postod kd23se4 » 16 Avg 2013, 18:49
This is what SID can display.
• A/C off due to high engine temperature.
• Antilock brake malfunction. Contact service.
• Stability control failure. Contact service.
• Traction control failure. Contact service.
• Use your seatbelts.
• Rear right seat backrest unlocked.
• Rear left seat backrest unlocked.
• Battery not charging. Make a safe stop. Contact service.
• Reduced engine power. Contact service.
• Brake malfunction. Make a safe stop. Contact service.
• Remote control battery low. Replace battery.
• Time for service. Contact service.
• Rear fog light failure.
• Tire pressure system failure. Contact service.
• Lock system failure. Contact service.
• Incorrect part detected. Contact service.
• Release park brake.
• Hot engine. Make a safe stop. Run engine on idle.
• Right rear turn indicator failure.
• Right brake light failure.
• Right front turn indicator failure.
• Right low beam failure.
• Right high beam failure.
• High mounted brake light failure.
• Immobiliser failure. Retry to start. Contact service.
• CHECK OK
• Airbag malfunction. Contact service.
• Headlamp levelling malfunction. Contact service.
• Brake fluid level low. Make a safe stop. Contact service.
• Coolant level low. Refill needed.
• Low engine oil level. Fill oil now.
• Washer fluid level low. Refill needed.
• Tire pressure low, rear right. Check tires.
• Tire pressure low, front right. Check tires.
• Tire pressure low, rear left. Check tires.
• Tire pressure low, front left. Check tires.
• Oil pressure low. Make a safe stop. Turn off engine.
• Engine malfunction. Contact service.
• Key not accepted. Contact service.
• Parking Assistance malfunction. Contact service.
• Right rear position light failure.
• Left rear position light failure.
• Tap brakes lightly before using cruise control.
• Flat tire rear right. Make a safe stop.
• Flat tire front right. Make a safe stop.
• Flat tire rear left. Make a safe stop.
• Flat tire front left. Make a safe stop.
• Lock engaged. Pull out key, turn steering wheel. Retry to start.
• Steering lock malfunction. Make a safe stop. Contact service.
• Parking assistance sensor disturbed.
• Tighten fuel filler cap.
• Close doors.
• Alarm activated during last arming period.
• Theft protection failure. Contact service.
• CHECKING
• Valet mode activated.
• Left rear turn indicator failure.
• Left brake light failure.
• Left front turn indicator failure.
• Left low beam failure.
• Left high beam failure.
• Gearbox malfunction. Limited performance. Contact service.
• X: standard key Y: valet key Key No: Z
• Gearbox too hot. Make a safe stop. Open hood to cool down
Re: Poruke koje daje SID
Postod TAZZ » 17 Avg 2013, 17:07
I jos mnoooooooooooogggggooooooo vise....
Korisnijih informacija... :whistling:
Povratak na “ELEKTRONIKA”
Korisnika u ovom forumu: Bing [Bot] i 2 gosta
