Modified Saab 9-3 X4R 802bhp
Strani i domaci projekti koji su interesantni,rest-mod projekti,itd.....
Postovi: 7136
Postod AERO » 31 Dec 2011, 17:01
Dakle...."al' ga je opravio - svaka mu cast"
CAR COLOUR
Porsche Titan Grey
ENGINE MODIFICATIONS
2.0-litre, four-cylinder 1994 saab 900 engine, standard head ported by mike billet, custom head bolts, 90.8mm bore, 78mm stroke, trollspeed 34mm inlet valves and 32mm outlet valves, wargia/trollspeed adjustable valve timing and adjustable cam tensioners, piper 298-degree cams with 12.9mm lift, je pistons, verdi rods, 9.35:1 compression ratio, oil filter removed, setrab oil cooler, spal fan, 8 x 720cc siemens injectors, 3.5 bar fuel pressure with twm fuel pressure regulator, 40-litre atl fuel cell, custom catch tank with two bosch 044 fuel pumps, 1.5-litre catch tank with double filters, two high-pressure fuel lines, wargia custom fuel rail, henrik (jesus) custom four-branch manifold with 44.5mm pipes, two tial 38mm wastegates, two tial dump valves, turbonetics/its t76 turbocharger, 3" pressure pipe from intercooler to turbo, 3" stainless steel exhaust system with 3.5" downpipe, racecoolings custom intercooler, racecoolings radiator, tibuc and trollspeed water pump, pectal t6 ecu. max power - 802bhp, max torque – 775nm at 2.9 bar boost using 105 octane race fuel
TRANSMISSION MODIFICATIONS
tractive five-speed sequential gearbox, ap racing carbon fibre 200mm triple-plate clutch, trollspeed lightweight flywheel, tractive four-wheel drive system, tractive hydraulic programmable active differentials: tractive 3.31:1 rear differential with volvo 850 steel diff housing, sellholm tuning 3.31:1 front differential, svea bid hybrid volvo/bmw driveshaft
SUSPENSION MODIFICATIONS
forza customised bilstein coilover setup front and rear, custom made setup by pelle at wargia
ALLOY WHEELS
10x20in bbs rs gt
TYRES
255/30/20 yokohama advan sport
BRAKES
front: tarox twelve-pot calipers with 380mm discs and 2006 saab 9-5 custom hubs. rear: tarox eight-pot calipers with 360mm discs and 2006 saab 9-5 custom hubs
Postovi: 7136
Re: Modified Saab 9-3 X4R 802bhp
Postod AERO » 19 Jan 2012, 15:03
Postod TAZZ » 19 Jan 2012, 15:12
JJJJJJJJJJJJJJJOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJ!!!!!!!!!!!!!!!!!!!!!!!!!! VIDI QURAVANKU!!!!!!!!!!!!!!!!!!! JJJJOOOOOJJJJJJ!!!!!
Postovi: 7136
Postod AERO » 19 Jan 2012, 15:15
I zbog felni i zbog karavana sam ti okacio .......Slika
Postovi: 7136
Postod AERO » 19 Jan 2012, 15:42
Postovi: 7136
Postod AERO » 24 Mar 2012, 23:55
Postovi: 7136
Postod AERO » 23 Apr 2012, 16:59
Slika Slika Slika kol'ka turbina jbt-eeeeee
troll 9-5
Postovi: 1999
Lokacija: Z E M U N
Postod troll 9-5 » 23 Apr 2012, 17:02
Slika u jbt...
Carlsson
Postovi: 2756
Lokacija: Banja Luka
Postod Carlsson » 23 Apr 2012, 18:41
jel ima motor ili je samo turbina Slika
Postovi: 7136
Postod AERO » 26 Okt 2013, 11:42
Povratak na “SAAB PROJEKTI”
