SAAB 2.8V6
O SAAB MOTORIMA
SAAB 2.8V6
Postod AERO » 11 Mar 2012, 13:03
dollce vita je napisao:2.8 V6?? ...da li neko zna par reci o ovom motoru, kakav je, ima li neke mane, kako se pokazao, itd...znam da je GM-ov, delio ga je 93 sa vektrom OPC...
Cim je Holden u pitanju,onda je i vektra,ali .....i Cadillac CTS Slika
U vektri je to bio top-of-the-line (230ks 2.8V6 turbo),a na OPC-u su ga nabrijali kao na saab-u Turbo X
U saab-u turbo X - Motor: 2.792 cm3 blok i glava od aluminijuma, Twin Scroll turbo, 24 ventila, Bosch Motronic elektronika motora, 280 KS pri 5.500 o/min, 400 Nm pri 2150 o/min. Ubrzanje iz mesta do 100 km/h: +- 5,9 s
Specifičan razvoj snage, nekarakterističan za turbo motore. Kod Turbo X-a nema tzv. “napada Obrtnog momenta” kao kod većine turbo motora.
Tad kad su ga izbacili (By Holden) - na blic procitah da je medju 10 najboljih na svetu(bio u tom momentu Slika )......
Na onom internacionalnom sajtu gde svi kace misljenje za sve modele automobila (vlasnici).....neki baja (koji je izasao i Mondea ST 226ks ) i seo u novog saab-a 2.8V6,zali se na neke druge stvari,ali za motor ,kaze da je ok.......njegov je jos bio doradjen by "HIRSCH" Slika
Evo nesto osnovno,pa cemo dalje kako se ko ukljuci....
...ima dve varijante: LP1 i LP9...... Neka rec vise ima OVDE i OVDE
LP1
A 2.8 L (2792 cc) LP1 variant was introduced in the 2005 Cadillac CTS. It has a 3.50 in (89.0 mm) bore, a 2.94 in (74.8 mm) stroke, and a 10.0:1 compression ratio. The LP1 was built in Saint Catharines, Ontario.
LP9 Turbo
The LP9 is a 2.8 L turbocharged version used for the Saab 9-3 and other GM vehicles. It has the same bore and stroke as the naturally aspirated LP1, however the compression ratio is reduced to 9.5:1. GM Powertrain Sweden (Saab Automobile Powertrain) was responsible for turbocharging the engine and it is built in Port Melbourne, Australia. Note that 'global' versions use the same horsepower rating for both metric and imperial markets (using imperial horsepowers) while Europe only versions are rated in metric horsepowers. Max torque are without torque limits used in some versions
Vozili smo: Saab Turbo X
CEO TEST
Re: SAAB 2.8V6
Postod kd23se4 » 11 Mar 2012, 14:13
Uopsteno govoreci, inzenjeri Saaba nikad nisu bili pod prinudom da koriste odredjeni agregat GM-a, tako da oni GM agregati koji su ugradjivani u Saab jesu bili dobri motori.
Jedini neslavni izuzetak je dizel 3.0 koji jeste proizveo Isuzu, ali sam na jednom mestu procitao da su motor projektovali bas inzenjeri Saab-a, a ne Renault-a ili Opela (posto se kod njih ugradjivao).
Sve u svemu hajka na GM treba najmanje da bude zbog motora, vec vise zbog neke politike koju su vodili prema Saabu.
Re: SAAB 2.8V6
Postod AERO » 11 Mar 2012, 15:16
Ma cim njega vozi Policija u South Africa - onda je vrh Slika
Evo OVDE su ga razbucali Slika ......jedan vice da su im lanci losi,drugi kaze nije tacno....itd
P.S. - sad citam nesto za Cadillac CTS 2.8 V6
.....pa izmedju ostalog kaze:
-Suburban consumption (l/100 km) – 8.4
-Average consumption (l/100 km) – 11.8
-Urban consumption (l/100 km) – 17.7
.....kuuuuuuku Slika Slika Slika ..........KLIK
Re: SAAB 2.8V6
Postod kd23se4 » 11 Mar 2012, 16:29
bice da nije toliko strasno -
KLIK
HIRSCH
Postovi: 579
Pridružio se: 14 Jan 2012, 00:00
Re: SAAB 2.8V6
Postod HIRSCH » 11 Mar 2012, 17:19
kd23se4 je napisao:bice da nije toliko strasno -
KLIK
zanimljivo... 17,7 verovatno pun gas...a, 11,5 -12,00 ono cruse kroz grad 7,8 banki, pa toliko meni trosi moj, stvarno je stedljiv...
Re: SAAB 2.8V6
Postod AERO » 11 Mar 2012, 17:31
Ma koje crno pun gas - budite ozbiljni .......pa kec trosi 10 - 11 litara
Ovo je potrosnja(prosek), koju oni sabiraju,i na kraju izvuku srednju vrednost......pritom,dosta njih se svaki dan kace na auto - ban,sto bitno utice na prosek......ali cim je lokal oko 50tak km,eto ga 15+.......i to njihovog benzina.
Daj ga vamo(u Beograd) u spic oko 7 ujutru,ili popodne kad se vracaju s posla, ima da bije 20 kao vrata!!!
...na nasu bezolovnu vodicu Slika Slika
Re: SAAB 2.8V6
Postod AERO » 11 Mar 2012, 17:42
Slika Evo ovde mu ostao zaglavljen sauh Slika Slika Slika
HIRSCH
Postovi: 579
Re: SAAB 2.8V6
Postod HIRSCH » 11 Mar 2012, 18:19
kao prvo kec nije auto, kao drugo... Slika salim se
Re: SAAB 2.8V6
Postod AERO » 11 Mar 2012, 18:25
Slika ......... Slika ..........Slika......KLIK
HIRSCH
Postovi: 579
Re: SAAB 2.8V6
Postod HIRSCH » 11 Mar 2012, 18:49
eee....tad su ga radili italijani to se ne racuna Slika
Re: SAAB 2.8V6
Postod AERO » 03 Apr 2012, 15:31
Re: SAAB 2.8V6
Postod AERO » 11 Maj 2012, 16:37
Re: SAAB 2.8V6
Postod AERO » 03 Nov 2012, 07:56
Re: SAAB 2.8V6
Postod AERO » 05 Sep 2013, 18:57
:hkf: :hkf:
Povratak na “MOTORI”
