OPEL Astra G Convertible 2.2DTi 2172 92 Y22DTR 09/2002->
OPEL Astra G Coupe 2.2DTi 2172 92 Y22DTR 09/2002->
OPEL Astra G Estate 2.0DTi 16V 1995 74 X20DTH, Y20DTH 08/1999->
OPEL Astra G Estate 2.2DTi 2172 92 Y22DTR 09/2002->
OPEL Astra G HB 2.0DTi 16V 1995 74 X20DTH, Y20DTH 08/1999->
OPEL Astra G HB 2.2DTi 2172 92 Y22DTR 09/2002->
OPEL Astra G Saloon 2.0DTi 16V 1995 74 X20DTH, Y20DTH 08/1999->
OPEL Astra G Saloon 2.2DTi 2172 92 Y22DTR 09/2002->
OPEL Frontera B 2.2DTi 2171 85 X22DTH, Y22DTH 10/1998->09/2002
OPEL Signum 2.0DTi 1994 74 Y20DTH 05/2003->
OPEL Signum 2.2DTi 2171 92 Y22DTR 05/2003->
OPEL Vectra C 2.0DTi 16V 1995 74 Y20DTH 04/2002->
OPEL Vectra C 2.2DTi 16V 2172 92 Y22DTR 04/2002->
OPEL Vectra C Estate 2.0DTi 1995 74 Y20DTH 10/2003->
OPEL Vectra C Estate 2.2DTi 2172 92 Y22DTR 10/2003->
OPEL Vectra C GTS 2.0DTi 16V 1995 74 Y20DTH 08/2002->
OPEL Vectra C GTS 2.2DTi 16V 2172 92 Y22DTR 08/2002->
OPEL Zafira 2.0DTi 16V 1995 74 Y20DTH 09/2000->
OPEL Zafira 2.2DTi 16V 2172 92 Y22DTR 01/2002->
SAAB 9-3 2.2TiD 2171 92 D223L 11/2000->09/2002
SAAB 9-3 2.2TiD 2171 85 D223L, X22DTH 02/1998->11/2000
SAAB 9-3 2.2TiD 2171 92 D223L 09/2002->
SAAB 9-5 2.2TiD 2171 88 D223L 03/2002->
SAAB 9-5 Estate 2.2TiD 2171 88 D223L 03/2002->
...takodje:Wahler nummer 7375D za Opel:
Astra G, Frontera B, Signum, Vectra C, Zafira A SAAB 9-3, 9-5(OE nummer: 851755)
Jeste, a za 2.2 TiD pase skoro sve od delova sto ide na 2.0 DTI i 2.2 DTI, dakle:
Lanci (sva tri), lancanici, hidro-zatezaci, kais, spaner, svi dihtunzi glava-karter
Filter za ulje i gorivo, senzori (pritisak ulja, radilica...).
NE PASE (da se neko ne zez...) nista od kvacila sem donjeg cilindra (onaj pored lamele) - on je npr. za Opel Zafiru 2.2DTI.
Trap: napred samo pasu mali stabilizatori sa spone - sa Astre F
Od tecnosti za sve Saabove 9-3 benzince i dizele vazi ista preporuka:
Mobil 1 (0W40), Opel Antifirz (BASF G34) i Opel menjacko ulje MTF0063
Re: Kompatibilnost sa drugim vozilima
Poslato: 02 Feb 2012, 15:43
Saab 9-3 I (98-02/03) : Vectra B Tockovi & Kocnice
Felne Rupa/ET odgovara za sve Vectre/Omege/Astre sa 5 rupa
Kocnice: zadnja kocnica disk/plocica/pakna Opel Vectra B 100% odgovara
napred plocica sa Astre H za 2.0 ili jace motore
Poslato: 07 Apr 2012, 12:17
od Gost
zna li neko od kojeg auta pase komutator za 9000 t iz 86? bosh 0 227 100 139 hitno mi treba
Poslato: 07 Apr 2012, 14:24
od Gost
nasao sam,od lade samare po bosch katalogu. . .
Poslato: 07 Apr 2012, 15:47
Lada 2108 3734 910 10
Opel 90140187
Volvo 1389939
Poslato: 18 Sep 2012, 20:10
od NikolaNes
jel zna mozda neko da li se poklapaju prednje plocice od 900turbo 2.0 '88 sa nekim drugim automobilom. u cg mi traze 50e i moram da cekam 15dana na isporuku
Poslato: 18 Sep 2012, 20:27
Plocice su samo za Saab 900 i 9000. Ustedu ces ostvariti tako sto ces otici kod drugog uvoznika, tj. uzeti neku drugu marku. Imas sledece opcije:
A.B.S. - 36622
ATE (najbolje) - 13.0460-2811.2
Bosch - 0986490680
Delphi - LP 131 ili LP 731
fri.tech - 153.0
Girling - 6104601
Jurid - 571535J
Lemförder - 20621
Optimal - 9638
Pagid - T5029
Quinton Hazell - BP851
Textar - 2106804
TRW - GDB460
Valeo - 168369 ili 598237
Ovde sam ti naveo najpoznatije marke koje bi trebalo da su zastupljene u CG. Nadji ko ih uvozi i neko ce biti jeftiniji.
NAPOMENA: Imas novu osovinu i strogo vodi racuna da napomenes da je model od 88-93, nikako stariji!!!
Saab broj: 8993974
Ja imam stariju osovinu (87) i cena za moj u TRW kvalitetu je bila oko 20-25€, cisto da imas orientaciju
Poslato: 18 Sep 2012, 20:52
od NikolaNes
hvala puno..dva puta me spasavas
Poslato: 18 Sep 2012, 21:05
Nema frke - zato, izmedju ostalog, vozim Saab. Ceo svet pravi delove za njih i mozes da biras - samo treba da znas odakle
EDIT AERO :
Poslato: 31 Okt 2012, 20:55
od NikolaNes
naletio sam na pumpu pa me intresuje jel moze u moj, pise da moze u sisavac
Ovo sa slike je pumpa za gorivo za karburator, a ne injection - ne bi mogao da je prisrafis negde i da hoces
Pumpa je sa modela 900c ili karburator motor B201c - verovatno ide na bregastu negde - radni pritisak oko 0,3bara
Ti imas elektricnu pumpu za gorivo koja radi na 3-5 bara, a to izgleda OVAKO
Ista pumpa ide i za "sisavac injection" - dakle model sa 118ks (ima ga nemanja81)
ja imam u onom drugom pumpu..moze li ona da crkne od stajanja?
Poslato: 31 Okt 2012, 23:40
retko! Pre se desi da strada ona guma u kojoj se pumpa nalazi - ako je citava cuvaj je kao oci u glavi - bez nje ne radi pumpa kako treba, a nova je 80€
Pumpa za 900i i 900 Turbo 8v trebalo bi da su iste tako da samo napred
Poslato: 31 Okt 2012, 23:48
od NikolaNes
jeeeeeeee
Poslato: 09 Dec 2012, 17:53
od Gost
A razvodna kapa i ruka za 204i? Je l' odgovara to od necega?
Poslato: 09 Dec 2012, 20:27
Razvopdna kapa - pase ti sa raznih citroena i Pezoa,mada je razlika u ceni je smesna, a u kvalitetu velika.....kupi original Bosch-ovu, samo im kazes koje je vozilo ili daj Bosch broj 1235522332
Razvodna ruka - isla je na Mercedese, ali ista prica, nazovi Trigemu i kupi original Bosch, Bosch br. 1234332366
Poslato: 09 Dec 2012, 20:31
od Gost
Ima li KD da ti nesto neznas?
svaka cast kralju
Poslato: 09 Dec 2012, 20:59
Boki je napisao:Ima li KD da ti nesto neznas?
svaka cast kralju
Jevandjelje po Mateji 7:7 "ko trazi nacice"
Poslato: 09 Dec 2012, 22:37
od Gost
Mnogo hvala
Poslato: 01 Feb 2013, 18:09
Zadnje kocione plocice za 9-5 yearsmodel from 1999, FC3, chassis no. from 025752, part number 5058110 - iste kao i za BME E46, E36 i Rover 75!
