TEHNICKA DOKUMENTACIJA ZA SAAB 9000
Poslato: 31 Dec 2011, 20:02
Re: TEHNICKA DOKUMENTACIJA ZA SAAB 9000
Poslato: 09 Jan 2012, 16:49
Jbg....(na Francuskom)....ali sve je
OVDE.....u PDF-u
Poslato: 22 Jan 2012, 17:47
Poslato: 06 Maj 2012, 12:55
od akvarijus
All 4 cylinder models 1985 to 1995 (UK - C to N registration)
These are the minimum maintenance intervals recommended by the manufacturer for vehicles driven daily. lf you wish to keep your vehicle in peak condition at all times, you may wish to perform some of these procedures more often.
lf the vehicle is driven in dusty areas, used to tow a trailer, or driven frequently at slow speeds (idling in traffic) or on short journeys, more frequent maintenance intervals are recommended.
Every 250 miles (400 km) or weekly
Check the engine oil level
Check the engine coolant level
Check the brake fluid level
Check the screen washer fluid level
Visually examine the tyres for tread depth, and wear
Check and if necessary adjust the tyre pressures
Check and if necessary top-up the battery electrolyte level - where applicable
Check the operation of the horn, all lights, and the wipers and washers
At first 6000 miles (10,000 km) or 12 months — whichever comes sooner
Change the engine oil and filter
Check and if necessary adjust the coolant antifreeze concentration
Steering and suspension check
Check and if necessary adjust the front wheel alignment
Check and if necessary top-up the power steering fluid level
Check the Fraction Control System (TCS)
Check the seat belts for operation and damage
Visually check the airbag system
Lubricate all hinges and locks
Clean the battery terminals
Check the headlight and foglight beam alignment
Road test
Every 12 000 miles (20 000 km) or 12 months — whichever comes sooner
Check the crankcase ventilation system
Check all hoses
Check and if necessary adjust the auxiliary drivebelt tension
Check the air conditioning refrigerant
Renew the ventilation air filter (after first renewal, every 24 000 miles)
Check the exhaust system
Renew the spark plugs (leaded petrol models only)
Check and if necessary top-up the manual transmission oil level
Check and if necessary top-up the automatic transmission fluid level
Check the driveshaft rubber gaiters
Check the front and rear brake pads and discs
Check all brake lines and flexible hoses
Check the suspension and shock absorbers
lubricate all hinges and locks
Road test
Every 24 000 miles (40 000 km) or 2 years — whichever comes sooner
In addition to all the items listed in the previous section, carry out the following:
Renew the air cleaner filter element
Renew the spark plugs (unleaded petrol models only)
Change the automatic transmission fluid and filter
Every 48 000 miles (80 000 km) or 3 years — whichever comes sooner
Renew the coolant/antifreeze
Every 96 000 miles (160 000 km)
Renew the fuel tilter
Engine Multigrade engine oil, viscosity SAE 10W/30, 10W/40, 5W/30 or 5W/40, to API SG and CCMC G4/G5 specifications
Cooling system Ethylene glycol-based antifreeze
Manual transmission 10W/30 or 10W/40 (synthetic oil not to be used)
Automatic transmission Dexron type II ATF
Driveshaft CV joints Outer driveshaft: Molycote VN 2461C lnner driveshaft: Mobil grease GS 57C
Brake and clutch hydraulic systems Hydraulic fluid to DOT 4
Hub/wheel bearings Multi-purpose lithium-based grease
Steering rack Multi-purpose lithium-based grease
Power steering Saab or GM power steering fluid
Capacities
Engine oil lncluding filter: B202 engine 4.2 litres
B234 engine (up to 1993) 4.3 litres
B204 and B234 engines (1994 onwards) 5.5 litres
Difference between MAX and MIN dipstick marks 1 .O litre
Cooling system
All engines 9.0 litres (approximate)
Manual transmission:
Up to 1993 2.5 litres
1994 onwards 1 .8 litres
Automatic transmission including torque converter and fluid cooler:
2.0 litre models 8.2 litres (approximate)
2.3 litre models 8.7 litres (approximate)
Service fluid change 3.0 to 3.5 litres
Fuel tank
1985 to 1 989 models 68 litres (1 5 gallons)
1990 and 1992-on models 66 litres (14.5 gallons)
1991 models 62 litres ( 13.6 gallons)
Power steering All models: 0.75 litre
Poslato: 07 Maj 2012, 09:37
od akvarijus
Poslato: 07 Maj 2012, 09:46
od akvarijus
Poslato: 28 Maj 2012, 00:40
Kolja je napisao:Zna li ili bolje receno hoce li neko opisati detaljno princip rada LH sistema koji su se ugradjivali u SAAB do pojave trionica. Sa kojim automobilima dele senzore,princip rada citaca,gde se nalaze,kako proveriti ispravnost istih i te gluposti. Bilo bi korisno. Nasao sam na netu da b202 (turbo) do '89 znaci do pojave Di sistema nemaju senzor radilice vec imaju u razvodniku hall effect transmiter preko kojeg daju signal paljenju. Kasnije se to izmestilo na radilicu jer je valjda bolje ili sta vec. Isto da LH 2.2 nema plus na osiguracu pumpe dok se ne zavergla i da preko onog hall effect senzora se daje signal pumpi za ukljucivanje(nije kao kod ostalih da kada se da kontakt pumpa sama ukljuci) . Kod injectiona ide drugacije,oni imaju senzor na radilici,ne u razvodniku i tako. Brdo fazona i fora na oko slicnih ali se bitno razlikuju kada se malo bolje zagleda. Nadam se da ne davim
Poslato: 18 Jun 2012, 21:54
SAAB 9000 1985-98 Spare part catalogue
Haynes SAAB 9000 SW scan
Poslato: 18 Jun 2012, 21:57
akvarijus-e .... ovaj part catalog sa brojevima delova je odlicna stvar
Poslato: 25 Jul 2012, 11:41
od akvarijus
Poslato: 28 Avg 2012, 00:48
Poslato: 14 Okt 2012, 18:52
9000 Gear selector housing replacement -
KLIK
9000 Gear Lever 86-93 -
KLIK
9000 Gear Position Adjust 86-93 -
KLIK
Poslato: 09 Jan 2013, 00:16
Poslato: 18 Jan 2013, 11:23
Poslato: 18 Jan 2013, 11:38
od Kolja
Ima na jos skrivenih mesta
Poslato: 19 Jan 2013, 12:17
Kolja je napisao:Ima na jos skrivenih mesta
Kojih,gde
Poslato: 19 Jan 2013, 12:41
od Kolja
Pa na nekoliko mesta imaju VIN brojevi koji nisu poznati sirim masama. Proverena informacija od cike koji je redovito
SAABove a i druge marke.Ne znam gde su ali ih ima. Krstenje prolazi i bez njih ali. . .
Poslato: 19 Jan 2013, 13:18
Bitno je,ako neces da kupis
...Cuo sam za to,ali nisam nikad dobio odgovor,gde...
Uglavnom srede ovaj u gepeku,na kosu i na motoru(njega nekad i ne diraju)...stakla...Imao sam iskustva sa takvim prodavcima....Bilo je
Poslato: 19 Jan 2013, 14:35
od Kolja
Ma ionako to vise slabo ko proverava od organa reda...
Poslato: 19 Jan 2013, 16:51
Kolja je napisao:Ma ionako to vise slabo ko proverava od organa reda...
Da li bi ti kupio takav auto?
Znam da je vise od 30%
u Srbiji...Ali ajd,kao zivimo u neznanju...i tesimo se da nas auto nije jedan od tih
Poslato: 19 Jan 2013, 17:59
od Kolja
Poslato: 19 Jan 2013, 19:01
Poslato: 26 Apr 2013, 21:53
1 Gearbox number
2 Modification plate (campaign plate)
3 Colour code and trim code
4 Colour code
5 Trim code
6 Engine number
7 VIN
8 Body number
9 VIN, stamped on body
Poslato: 10 Maj 2013, 11:52
Poslato: 08 Avg 2013, 16:16
[link_open=
http://www.saabsportclub.com/site/ssc_t ... uto,0,1232]9000_3-5_Ordinateur EDU_90-94[/link_open]
[link_open=
http://www.saabnet.com/tsn/faq/9000wiringdiagrams.pdf]Saab 9000 Wiring Diagrams[/link_open]
[link_open=
http://www.saabclub.su/files/Articles/E ... %20CSE.pdf]1998 SYSTEM WIRING DIAGRAMS SAAB 9000[/link_open]
