Cim je Holden u pitanju,onda je i vektra,ali .....i Cadillac CTSdollce vita je napisao:2.8 V6?? ...da li neko zna par reci o ovom motoru, kakav je, ima li neke mane, kako se pokazao, itd...znam da je GM-ov, delio ga je 93 sa vektrom OPC...
U vektri je to bio top-of-the-line (230ks 2.8V6 turbo),a na OPC-u su ga nabrijali kao na saab-u Turbo X
U saab-u turbo X - Motor: 2.792 cm3 blok i glava od aluminijuma, Twin Scroll turbo, 24 ventila, Bosch Motronic elektronika motora, 280 KS pri 5.500 o/min, 400 Nm pri 2150 o/min. Ubrzanje iz mesta do 100 km/h: +- 5,9 s
Specifičan razvoj snage, nekarakterističan za turbo motore. Kod Turbo X-a nema tzv. “napada Obrtnog momenta” kao kod većine turbo motora.
Tad kad su ga izbacili (By Holden) - na blic procitah da je medju 10 najboljih na svetu(bio u tom momentu
)......Na onom internacionalnom sajtu gde svi kace misljenje za sve modele automobila (vlasnici).....neki baja (koji je izasao i Mondea ST 226ks ) i seo u novog saab-a 2.8V6,zali se na neke druge stvari,ali za motor ,kaze da je ok.......njegov je jos bio doradjen by "HIRSCH"
Evo nesto osnovno,pa cemo dalje kako se ko ukljuci....
...ima dve varijante: LP1 i LP9...... Neka rec vise ima OVDE i OVDE
LP1
A 2.8 L (2792 cc) LP1 variant was introduced in the 2005 Cadillac CTS. It has a 3.50 in (89.0 mm) bore, a 2.94 in (74.8 mm) stroke, and a 10.0:1 compression ratio. The LP1 was built in Saint Catharines, Ontario.
LP9 Turbo
The LP9 is a 2.8 L turbocharged version used for the Saab 9-3 and other GM vehicles. It has the same bore and stroke as the naturally aspirated LP1, however the compression ratio is reduced to 9.5:1. GM Powertrain Sweden (Saab Automobile Powertrain) was responsible for turbocharging the engine and it is built in Port Melbourne, Australia. Note that 'global' versions use the same horsepower rating for both metric and imperial markets (using imperial horsepowers) while Europe only versions are rated in metric horsepowers. Max torque are without torque limits used in some versions
Vozili smo: Saab Turbo X
CEO TEST
......jedan vice da su im lanci losi,drugi kaze nije tacno....itd
