Re: SAAB 900 OG
Poslato: 26 Dec 2011, 00:13
Pokusacu da ovim postom pomognem u desifrovanju broja sasije - eventualnog modela 900(ma da ima i par podataka za 99 i 9000)
Dakle ...17 oznaka i svaka po nesto znaci....
1981-1983 VIN style
This marked the first year for the international 17 digit VIN code. It keeps all manufacturers on the same playing field, and you can identify make, model, and some equipment off of a VIN.
YS3AT34S2B1XXXXXX
The first three digits are the country and manufacturer code.
YS3 is used for cars made in Sweden
YK1 is used for cars made in Finland
The next digit is the car model.
A = 900
B = 99
The 5th digit is the series.
G = GL
S = EMS
E = GLE
T = Turbo
The 6th digit is the Body Type or the number of doors
3 = 3-door Combi Coupe (CK)
4 = 4-door Sedan (SN)
5 = 5-door Combi Coupe
The 7th digit is the Engine type
1 = Single carbeuretter
2 = Twin-carburetter
3 = Injection
4 = Turbocharged
The 8th digit is for Safety equipment
A = Airbag
P = Passive seat belts
S = Active seat belts
Note: I doubt anything other than 'S' was used here, as Passives and Airbags were not introduced until after the VIN spec was changed.
The 9th digit is a check digit, which will be 0-9 or X. No meaning, other than to make sure it is a valid VIN.
The 10th digit is the Model Year.
B = 1981
C = 1982
D = 1983
Position 11 is the assembly plant or line
1 = Trollhättan line #1
2 = Trollhättan line #2
3 = Arlöv, Sweden
6 = Nystad, Finland - Saab 99
7 = Nystad, Finland - Saab 900
Lastly, positions 12 through 17 are the serial number of that model on that line.
1984-1985 VIN style
A few changes for the international 17 digit VIN code. Position 7 becomes the transmission type, and 8 becomes the engine type. Also, all Saabs use the same manufacturer code.
YS3AT35S9E1XXXXXX
YS3 is used for Saab cars
A = 900
B = 99
C = 9000
L = Low series
M = 900 (base) - Medium
H = 900 S - High
T = Turbo
E = Extra High
2 = 2-door sedan
6 = 4-door Sedan, Extended Length (CD)
The 7th digit is the Transmission type
4 = 4-speed manual
5 = 5-speed manual
6 = 3-speed Automatic
The 8th digit is the Engine type
C = Carburetter
T = Twin Carburetter
J = Fuel Injection
S = Turbo (8-valve)
L = Turbo & intercooler (16-valve)
E = 1984
F = 1985
3 = Arlöv, Sweden
6 = Nystad, Finland
7 = Nystad, Finland
1986 on VIN style
YS3AT35S9E1XXXXXX
A = 900
B = 99
C = 9000
D = 900 2nd generation
B = i
C = i16
D = Turbo
Sometime after 1986, this was changed to "For Internal Use Only". Probably as a result of a myriad of models sold around the world.
2 = 2-door sedan
7 = 2-door Convertible (CV)
Note the missing 5-door
4 = 4-speed manual
5 = 5-speed manual
8 = 4-speed Automatic
B = Fuel Injection, B234 (2.3 liter 16v)
D = Fuel Injection, B202 (16-v)
E = Fuel Injection, B212 (2.1 liter 16v)
J = Fuel Injection, B201 (8-v)
L = Turbo, B202 & intercooler (16-valve)
M = Turbo, B234
N = Turbo, B204 & intercooler (2.0 liter 16v with balance shafts)
S = Turbo, B201 (8-valve)
S = Turbo, B202 Low-pressure turbo (16-valve)
V = 2.5 liter V-6
G = 1986
H = 1987
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
P = 1993
R = 1994
S = 1995
T = 1996
1 = Trollhättan line A
2 = Trollhättan line B
3 = Arlöv, Sweden
5 = Malmö, Sweden
6 = Nystad, Finland
7 = Nystad, Finland
8 = Nystad, Finland (9000)
9 = Trollhättan Line C
1981-1983 VIN style
YS3AT34S2B1XXXXXX
A = 900
B = 99
G = GL
S = EMS
E = GLE
T = Turbo
3 = Injection
4 = Turbocharged
A = Airbag
B = 1981
C = 1982
D = 1983
3 = Arlöv, Sweden
1984-1985 VIN style
YS3AT35S9E1XXXXXX
A = 900
B = 99
C = 9000
L = Low series
H = 900 S - High
T = Turbo
E = Extra High
2 = 2-door sedan
4 = 4-speed manual
5 = 5-speed manual
C = Carburetter
J = Fuel Injection
S = Turbo (8-valve)
E = 1984
F = 1985
3 = Arlöv, Sweden
6 = Nystad, Finland
7 = Nystad, Finland
1986 on VIN style
YS3AT35S9E1XXXXXX
A = 900
B = 99
C = 9000
B = i
C = i16
D = Turbo
2 = 2-door sedan
4 = 4-speed manual
5 = 5-speed manual
M = Turbo, B234
V = 2.5 liter V-6
G = 1986
H = 1987
J = 1988
K = 1989
L = 1990
M = 1991
N = 1992
P = 1993
R = 1994
S = 1995
T = 1996
3 = Arlöv, Sweden
5 = Malmö, Sweden
6 = Nystad, Finland
7 = Nystad, Finland
[/img]
.......na blic se pojavljuje.Jel znas o cemu ti pricam......bas sam imao nameru da te pitam dal znas nesto o tome
