Skoro 560ks sa Taiwan-a
Strani i domaci projekti koji su interesantni,rest-mod projekti,itd.....
Postod AERO » 26 Mar 2012, 20:06
Sta reci Slika .......momak se poigrao sa svojim 9-5.
MapTun performance mu uradio motor i jos po nesto,i evo kako je ispalo Slika
Slika Slika Slika Slika
Year: 2000
Effect/torque: 520 Hp/537 Nm
Performance
Short time peak 560hp
Engine, gearbox and exhaust system
(1)MapTun customize ECU and engine rebuilding
(2)MapTun Hybird Turbo Garrett GT35R A/R .70 & HKS GT3040 turbine T25 flange A/R 1.01, 1.0bar, 580~600hp+
(3)MapTun Turbo Water/oil lines
(4)MapTun Camchafts 276/10.4
(5)MapTun 34/ 32mm valves, valve springs
(6)MapTun 9-5 Fuel system for 500+ hp
(7)MapTun 960cc injectors
(8)Wössner Forge pistons
(9)Pauter rods
(10)MapTun Race cat 100 CPI
(11)HKS GTII 50mm Wastegate
(12)HKS GT-type Intercooler
(13)Turbosmart blowoff valve compact dual port 25mm
(14)Abbott Racing Delivery Pipe
(15)Quaife LSD
(16)AEM dryflow filter
(17)Flex-a-lite cooling fan
(18)JT 3" downpipe
(19)SPEC stage 2+ 9-5 240 mm
(20)Hsia Special exhaust system (middle & rear)
(21)Hsia Tubular exhaust manifold
(22)Horsepowerfreaks Borla Turbo XL Performance Mufflers
(23)Borla 4” tips
Chassis
(1)H&R Coil over kit
(2)Abbottracing Uprated Anti-Roll Bars
Tires, rims and breaks
(1)WP 12-pistons yokes & 385mm discs(front), 6-pistons yokes & 330mm
(2)Horsepowerfreaks HRE 545 wheel Front: 10jx20 295/25/R20 CSC3; Rear: 11jx20 305/25/R20 CSC3
Interior
(1)Hirsch Silver Carbon Steering wheel
(2)Hirsch Carbon Dashboard, gearbox cover, Aluminum covers SID & ACC, Carbon cover Stereo
(3)Horsepowerfreaks Recaro Pro Racer HANS Seats & Profi SPG, Seat Brackets, Flat base slider
(4)Horsepowerfreaks Sparco 6 PT HANS Formula Seat Belt Harnesses (04796H) & 6 PT Seat Belt Harnesses (04827BM)
(5)Horsepowerfreaks Sparco WRX Harness Bars
(6)Defi all meters
(7)Innovate A/F meter
(8)AEM Voltmeter Gauges
(9)GARMIN GPS
Styling
(1)Taiwan JGTC customize special aerostyling (Hsia design, JGTC made)
(2)Taiwan SONIC coating
(3)Hsia Black flag
(4)Customize GT-Wing 1600mm
(5)Tucheng SAAB assembles & test
Evo sajta KLIK a ako nekom treba prevod,obratite se Carlssonu - on preferira te stvari sa istoka Slika
troll 9-5
Postovi: 1999
Lokacija: Z E M U N
Re: Skoro 560ks sa Taiwan-a
Postod troll 9-5 » 26 Mar 2012, 23:28
Dobar je! Kol'ko pokazivaca na tabli Slika
Postod AERO » 13 Maj 2012, 17:08
Postod AERO » 16 Jun 2012, 00:04
Postod AERO » 13 Okt 2012, 15:07
Postod TAZZ » 13 Okt 2012, 15:14
odvratan widebody kit
Perkele
Postovi: 898
Lokacija: Indjija
Postod Perkele » 13 Okt 2012, 15:18
Izgled mi je grozan, e sad sto se tice motora to je za respekt!
Postod Gost » 13 Okt 2012, 21:29
To nemoze da izdrzi naprezanja po gasu vise od koju hiljadarku kilometara i razletece se sve u tri lepe PM.to je po meni upucana lova samo za gledanje,a realno je odvratan.
Postod AERO » 03 Nov 2012, 07:05
Povratak na “SAAB PROJEKTI”
